ArcGIS.Core.CIM Namespace / CIMVoxelColorUniqueValue Class / Visible Property
Example
    Visible Property (CIMVoxelColorUniqueValue)
    Gets or sets a value indicating whether this class is visible.
    Syntax
    Public Property Visible As Boolean
    public bool Visible {get; set;}
    Example
    Change The Visibility on a CIMVoxelColorUniqueValue class
      // Note: call within QueuedTask.Run()
        //Get the variable profile whose renderer will be changed
        var variable = voxelLayer.SelectedVariableProfile;
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Discrete)
          return;//must be Discrete to have a UV Renderer...
        var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
        //A CIMVoxelUniqueValueRenderer consists of a collection of
        //CIMVoxelColorUniqueValue classes - one per discrete value
        //in the associated variable profile value array
        //Get the first class
        var classes = renderer.Classes.ToList();
        var unique_value_class = classes.First();
        //Set its visibility off
        unique_value_class.Visible = false;
        //Apply the change to the renderer
        renderer.Classes = classes.ToArray();
        //apply the changes
        variable.SetRenderer(renderer);
    Requirements
