ArcGIS.Core.CIM Namespace / CIMMapDocument Class
Properties Methods Events
    CIMMapDocument Class Members
    The following tables list the members exposed by CIMMapDocument.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the binary references of the document.
    Public Property Gets or sets the build an item was created with. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Public Property Gets or sets the elevation surface layer definitions of the map document.
    Public Property Gets or sets the elevation unit override of the map document.
    Public Property Gets or sets the layer definitions of the map document.
    Public Property Gets or sets the link chart definitions of the map document.
    Public Property Gets or sets the location unit override of the map document.
    Public Property Gets or sets the map definition of the map document.
    Public Property Gets or sets the table definitions of the map document.
    Public Property Gets or sets the timeline definitions of the map document.
    Public Property Gets or sets document version. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Public Property Gets or sets the video definitions of the map document.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMapDocument.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMapDocument with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMapDocument and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
