ArcGIS.Core.CIM Namespace / CIMTimeline Class
Properties Methods Events
    CIMTimeline Class Members
    The following tables list the members exposed by CIMTimeline.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the time units used in summary view bin time.
    Public Property Gets or sets the time at the end of the timeline.
    Public Property Gets or sets a value indicating whether the timeline is expanded in the contents pane.
    Public Property Gets or sets a value indicating whether the items in the timeline are visible based on the map extent.
    Public Property Gets or sets a value indicating whether the items in the timeline are visible based on range.
    Public Property Gets or sets a value indicating whether the items in the timeline are visible based on the map selection.
    Public Property Gets or sets a value indicating whether the timeline syncs with the map time slider.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the URI of the binary reference containing the selection set.
    Public Property Gets or sets a value indicating whether the timeline swimlanes show labels.
    Public Property Gets or sets a value indicating whether the timeline shows swimlanes.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the time at the beginning of the timeline.
    Public Property Gets or sets the timeline swimlanes.
    Public Property Gets or sets the theme of the timeline. e.g. Light, Medium, or Dark.
    Public Property Gets or sets the time indicator. e.g. Small, Medium, or Large.
    Public Property Gets or sets the text symbol for the timeline.
    Public Property Gets or sets time units used in the timeline scale.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the timeline view type.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTimeline.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTimeline with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTimeline and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
