ArcGIS.Desktop.Mapping Namespace / Layer Class / GetZs Method
    GetZs Method
    Overload List
    OverloadDescription
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Obtains a point geometry with Z for the specified x,y; where the Z value is populated from the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
