ArcGIS.Desktop.Mapping Namespace / Layer Class / GetZs Method / GetZs(Geometry) Method
the input geometry
Example
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetZs( _
       ByVal geometry As Geometry _
    ) As SurfaceZsResult
    Parameters
    geometry
    the input geometry
    Return Value
    A result that contains a status, plus an output geometry only if the status is favorable.
    Exceptions
    ExceptionDescription
    The input geometry is null.
    Remarks
    If the layer has no data at a particular input geometry point, then the corresponding output geometry point Z will be set to the value specified in SurfaceZsMissingHandler.DefaultOutputZ.
    Use CanGetZs to determine if the layer can be used as an elevation source before calling this function.
    Example
    Get Z values from a layer
        TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
        //Note: This method must be called on the MCT
        MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center; //Any Map Point
        Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
        if (tinLayer.CanGetZs())
            // get z value for a mapPoint
            var zResult = tinLayer.GetZs(mapPoint);
            if (zResult.Status == SurfaceZsResultStatus.Ok)
                // cast to a mapPoint
                var mapPointZ = zResult.Geometry as MapPoint;
                var z = mapPointZ.Z;
            // get z values for a polyline
            zResult = tinLayer.GetZs(polyline);
                var polylineZ = zResult.Geometry as Polyline;
    Get Z values from a TIN Layer
      // Note: Needs QueuedTask to run
            // cast to a Polyline
    Requirements
    ArcGIS Pro version: 3.4 or higher.
