GetZs(Geometry,SurfaceZsMissingHandler) Method
Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the layer.
This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- geometry
- the input geometry
- missingHandler
- Provides options to handle missing Zs
Return Value
A result that contains a status, plus an output geometry only if the status is favorable.
Get Z values from a layer
TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
//Note: This method must be called on the MCT
MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center; //Any Map Point
Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
if (tinLayer.CanGetZs())
// get z value for a mapPoint
var zResult = tinLayer.GetZs(mapPoint);
if (zResult.Status == SurfaceZsResultStatus.Ok)
// cast to a mapPoint
var mapPointZ = zResult.Geometry as MapPoint;
var z = mapPointZ.Z;
// get z values for a polyline
zResult = tinLayer.GetZs(polyline);
var polylineZ = zResult.Geometry as Polyline;
ArcGIS Pro version: 3.4 or higher.
