ArcGIS.Desktop.Mapping Namespace / Map Class / GetLocationUnitFormat Method
Example
    Gets the current map location unit format for the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    Remarks
    Map location unit formats are used to format the coordinate system display at the bottom of the map or scene as well as format the scale combo box.
    Display units
    Example
    Get the Current Map Location Unit
      //var map = MapView.Active.Map;
      await QueuedTask.Run(() =>
        //Get the current location unit
        var loc_unit = map.GetLocationUnitFormat();
        var line = $"{loc_unit.DisplayName}, {loc_unit.UnitCode}";
        System.Diagnostics.Debug.WriteLine(line);
    Format a Location Using the Current Map Location Unit
      //Get the current view camera location
      var center_pt = new Coordinate2D(mapView.Camera.X, mapView.Camera.Y);
      var loc_unit = await QueuedTask.Run(() => map.GetLocationUnitFormat());
      //Format the camera location
      var str = loc_unit.FormatLocation(center_pt, map.SpatialReference);
      System.Diagnostics.Debug.WriteLine($"Formatted location: {str}");
    Requirements
