ArcGIS.Desktop.Mapping Namespace / Map Class / SetElevationUnitFormat Method
The elevation unit format to set
Example
    Sets the current scene elevation unit format. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetElevationUnitFormat(
       DisplayUnitFormat unitFormat
    Public Sub SetElevationUnitFormat( _
       ByVal unitFormat As DisplayUnitFormat _
    Parameters
    unitFormat
    Exceptions
    ExceptionDescription
    unit format is of the wrong type
    unit format is not in the list of available elevation unit formats
    elevation unit format can only be set on a scene
    Remarks
    Calling SetElevationUnitFormat on anything other than a scene will result in a System.InvalidOperationException.
    Elevation unit format must be of type ArcGIS.Desktop.Core.UnitFormats.UnitFormatType.Distance or a System.ArgumentException will be thrown.
    The elevation unit format must be in the list of available distance unit formats for the project - ArcGIS.Desktop.Core.UnitFormats.DisplayUnitFormats.GetProjectUnitFormats or a System.ArgumentException will be thrown.
    The elevation unit format is used to format the units used by the coordinate system display at the bottom of the scene that shows elevation as well as format the scale combo box.
    unitFormat must be in the list of available elevation unit formats or a System.ArgumentException is thrown. Refer to: GetAvailableElevationUnitFormats.
    Example
    Set the Elevation Unit for the Current Map
      //Trying to set the elevation unit on a map other than
      //a scene will throw an InvalidOperationException
      await QueuedTask.Run(() =>
        if (map.IsScene)
          //Get the list of available elevation unit formats
          //for the current map
          var loc_units = map.GetAvailableElevationUnitFormats();
          //arbitrarily use the last unit in the list
          map.SetElevationUnitFormat(loc_units.Last());
    Requirements
