ArcGIS.Desktop.Mapping Namespace / Map Class / SetLocationUnitFormat Method
The location unit format to set
Example
    Sets the current map location unit format for the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetLocationUnitFormat(
       DisplayUnitFormat unitFormat
    Public Sub SetLocationUnitFormat( _
       ByVal unitFormat As DisplayUnitFormat _
    Parameters
    unitFormat
    Exceptions
    ExceptionDescription
    unit format is of the wrong type
    unit format is not in the list of available location unit formats
    Remarks
    Map location unit formats are used to format the coordinate system display at the bottom of the map or scene as well as format the scale combo box.
    Display units.
    Unit format must be of type ArcGIS.Desktop.Core.UnitFormats.UnitFormatType.Location or a System.ArgumentException will be thrown.
    The location unit format must be in the list of available location unit formats for the map or a System.ArgumentException will be thrown. Refer to: GetAvailableLocationUnitFormats. Note: If the map is using a GCS, linear unit formats are not included (in the list of available units).
    Example
    Set the Location Unit for the Current Map
      //Get the list of available location unit formats
      //for the current map
      await QueuedTask.Run(() =>
        var loc_units = map.GetAvailableLocationUnitFormats();
        //arbitrarily use the last unit in the list
        map.SetLocationUnitFormat(loc_units.Last());
    Requirements
