ArcGIS.Core.CIM Namespace / CIMFilteredFindPathsResult Class
Properties Methods Events
    CIMFilteredFindPathsResult Class Members
    The following tables list the members exposed by CIMFilteredFindPathsResult.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the configuration warning. When no path has been found, and the value is different from FFPConfigurationWarning.None, it is likely that the user made an unintended mistake in the configuration.
    Public Property Gets or sets the error. An error occurred if this object is not null.
    Public Property Gets or sets the execution warnings.
    Public Property Gets or sets the paths found by the Filtered Find Paths search.
    Public Property Gets or sets the statistics of the Filtered Find Paths search.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFilteredFindPathsResult.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFilteredFindPathsResult with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFilteredFindPathsResult and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
