ArcGIS.Core.CIM Namespace / CIMMaplexStackingSeparator Class
Properties Methods Events
    CIMMaplexStackingSeparator Class Members
    The following tables list the members exposed by CIMMaplexStackingSeparator.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the separator as a string of one character.
    Public Property Gets or sets a value indicating whether or not to split after the separator.
    Public Property Gets or sets a value indicating whether or not to force a split at every instance of the separator.
    Public Property Gets or sets a value indicating whether or not the separator should be visible after stacking.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMaplexStackingSeparator.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMaplexStackingSeparator with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMaplexStackingSeparator and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
