CreateInvestigation(String,String) Method
Creates a new KnowledgeGraphInvestigation in the project.
This method must be called on the MCT. Use QueuedTask.Run.
Create an Investigation
await QueuedTask.Run(() =>
var investigation = KnowledgeGraphInvestigationFactory.Instance.CreateInvestigation(url, "myInvestigation");
//TODO - use the investigation
Create and open an investigation pane
ProApp.Panes.CreateInvestigationPaneAsync(investigation);
ArcGIS Pro version: 3.5 or higher.
