ArcGIS.Desktop.Presentations Namespace / PresentationElementFactory Class / CreateGraphicElement Method / CreateGraphicElement(IElementContainer,CIMGraphic,String,Boolean,ElementInfo) Method
The parent element container. It can be a presentation page or a group element that is associated with a presentation page.
The input graphic
Element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    Creates a ArcGIS.Desktop.Layouts.GraphicElement based on the input ArcGIS.Core.CIM.CIMGraphic and element properties.
    Syntax
    Public Overloads Function CreateGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal cimGraphic As CIMGraphic, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    cimGraphic
    The input graphic
    elementName
    select
    elementInfo
    Return Value
    Remarks
    Example
    Create elements on a presentation page
      //Note: Must be on QueuedTask
      //create a picture element
      var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
       "homepage-tile-podcast-business-resilience-climate-change.jpg";
      //Build a geometry to place the picture
      Coordinate2D ll = new Coordinate2D(3.5, 1);
      Coordinate2D ur = new Coordinate2D(6, 5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //create a picture element on the page
      var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
      //create a text element
      //Set symbology, create and add element to a presentation page
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
      //use ElementInfo to set placement properties
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      string textString = "My text";
      var textPos = new Coordinate2D(5, 3).ToMapPoint();
      var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
        TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
      //create a group element with elements created above
      var elmList = new List<Element> { gElement, tElement };
      GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
    Requirements
    ArcGIS Pro version: 3.5 or higher.
