ArcGIS.Desktop.Presentations Namespace / PresentationElementFactory Class / CreateGraphicElement Method / CreateGraphicElement(IElementContainer,Geometry,CIMSymbol,String,Boolean,ElementInfo) Method
The parent element container. It can be a presentation page or a group element that is associated with a presentation page.
The geometry to be used for the graphic element
The symbol to be used for the graphic element (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    Creates a ArcGIS.Desktop.Layouts.GraphicElement based on the input geometry and associated symbol and properties (optional).
    Syntax
    Public Overloads Function CreateGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal geometry As Geometry, _
       Optional ByVal symbol As CIMSymbol, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    geometry
    symbol
    elementName
    select
    elementInfo
    Return Value
    Example
    Create elements on a presentation page
      //Note: Must be on QueuedTask
      //create a picture element
      var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
       "homepage-tile-podcast-business-resilience-climate-change.jpg";
      //Build a geometry to place the picture
      Coordinate2D ll = new Coordinate2D(3.5, 1);
      Coordinate2D ur = new Coordinate2D(6, 5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //create a picture element on the page
      var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
      //create a text element
      //Set symbology, create and add element to a presentation page
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
      //use ElementInfo to set placement properties
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      string textString = "My text";
      var textPos = new Coordinate2D(5, 3).ToMapPoint();
      var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
        TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
      //create a group element with elements created above
      var elmList = new List<Element> { gElement, tElement };
      GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
    Requirements
    ArcGIS Pro version: 3.5 or higher.
