ArcGIS.Desktop.Presentations Namespace / IPresentationElementFactory Interface / CreatePredefinedShapeGraphicElement Method / CreatePredefinedShapeGraphicElement(IElementContainer,PredefinedShape,Envelope,CIMPolygonSymbol,String,Boolean,ElementInfo) Method
The parent element container. It can be a presentation page or a group element that is associated with a presentation page.
The shape type of the graphic
The graphic bounding box
The symbol to be used with the graphic (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
    Creates a polygon graphic of the specified ArcGIS.Desktop.Layouts.PredefinedShape using the provided location, optional size dimensions, and symbol.
    Syntax
    Overloads Function CreatePredefinedShapeGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal shapeType As PredefinedShape, _
       ByVal bounds As Envelope, _
       Optional ByVal polySymbol As CIMPolygonSymbol, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    shapeType
    bounds
    polySymbol
    elementName
    select
    elementInfo
    Return Value
    Requirements
    ArcGIS Pro version: 3.5 or higher.
