ArcGIS.Core.CIM Namespace / CIMMapTimeDisplay Class
Properties Methods Events
    CIMMapTimeDisplay Class Members
    The following tables list the members exposed by CIMMapTimeDisplay.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the current time extent.
    Public Property Gets or sets the default time interval.
    Public Property Gets or sets the default time interval units.
    Public Property Gets or sets the default time window.
    Public Property Gets or sets a value indicating whether date field values should be projected to the map's time reference for display.
    Public Property Gets or sets the full time extent.
    Public Property Gets or sets a value indicating whether or not this map has live data.
    Public Property Gets or sets the time reference.
    Public Property Gets or sets the time relation.
    Public Property Gets or sets the time value.
    Public Property Gets or sets a cached set of unique OLE date values. Expected to be in the CIMMapTimeDisplay's TimeReference.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMapTimeDisplay.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMapTimeDisplay with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMapTimeDisplay and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
