ArcGIS.Core.CIM Namespace / CIMMapView Class
Properties Methods Events
    CIMMapView Class Members
    The following tables list the members exposed by CIMMapView.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the camera of the view.
    Public Property Gets or sets the camera effect definition for the scene.
    Public Property Gets or sets the color vision deficiency mode of the view.
    Public Property Gets or sets the exploratory analysis definitions for the view.
    Public Property Gets or sets the scene's field-of-view in degrees (value must be between 35 and 70). Only used when the scene is in Perspective draw mode.
    Public Property Gets or sets the floor filter settings of the view.
    Public Property Gets or sets the instance identifier of this view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the layer ranges of the view.
    Public Property Gets or sets a value indicating whether all animated symbol playback is in paused state for the view.
    Public Property Gets or sets a value indicating whether drawing is in paused state for the view.
    Public Property Gets or sets the post-processing effect definitions for the scene.
    Public Property Gets or sets the range slider settings of the view.
    Public Property Gets or sets the scene's drawing mode.
    Public Property Gets or sets the map time display of the view.
    Public Property Gets or sets the time slider settings of the view.
    Public Property Gets or sets the vertical exaggeration of the view.
    Public Property Gets or sets the path of the item in the view. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the map viewing mode of the view.
    Public Property Gets or sets the view type as a string. (Inherited from ArcGIS.Core.CIM.CIMView)
    Public Property Gets or sets the visual effect definition for the scene.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMapView.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMapView with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMapView and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
