ArcGIS.Core.CIM Namespace / CIMDataEngineeringStatisticColumn Class
Properties Methods Events
    CIMDataEngineeringStatisticColumn Class Members
    The following tables list the members exposed by CIMDataEngineeringStatisticColumn.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the column is frozen.
    Public Property Gets or sets a value indicating whether the column is sorted.
    Public Property Gets or sets a value indicating whether the column is visible.
    Public Property Gets or sets the column name.
    Public Property Gets or sets a value indicating the sort direction.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMDataEngineeringStatisticColumn.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMDataEngineeringStatisticColumn with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMDataEngineeringStatisticColumn and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
