CreateAsync(CreateProjectSettings) Method
Creates a new project with properties determined by CreateProjectSettings
Parameters
- createProjectSettings
- (optional) The settings that will be use to create a new project. (default value = null)CreateProjectSettings
Return Value
A Task returning the new project that was created
Create a new project
//Create a new project using Pro's default settings
var defaultProjectSettings = Project.GetDefaultProjectSettings();
var project = Project.CreateAsync(defaultProjectSettings).Result;
// Use project
Create a new project with specified name
//Settings used to create a new project
CreateProjectSettings projectSettings = new()
//Sets the name of the project that will be created
// example: projectName = @"C:\Data\MyProject1\MyProject1.aprx"
Name = projectName
//Create the new project
var project = Project.CreateAsync(projectSettings).Result;
// Use project
Create new project using Pro's default settings
//Get Pro's default project settings.
//Create a new project using the default project settings
// Use project
New project using a custom template file
//Sets the project's name
Name = projectName,
//Path where new project will be stored in
LocationPath = @"C:\Data\NewProject",
//Sets the project template that will be used to create the new project
TemplatePath = @"C:\Data\MyProject1\CustomTemplate.aptx"
// Use project
Create a project using template available with ArcGIS Pro
CreateProjectSettings proTemplateSettings = new()
Name = projectName,
//Select which Pro template you like to use
TemplateType = TemplateType.Catalog
//TemplateType = TemplateType.LocalScene
//TemplateType = TemplateType.GlobalScene
//TemplateType = TemplateType.Map
var project = Project.CreateAsync(proTemplateSettings).Result;
// Use project
Create Project with Template
var projectFolder = Path.Combine(
Environment.GetFolderPath(
Environment.SpecialFolder.MyDocuments),
@"ArcGIS\Projects");
CreateProjectSettings ps = new()
Name = projectName,
LocationPath = projectFolder,
TemplatePath = templatePath
var project = Project.CreateAsync(ps).Result;
//Use project;
Create an empty project
//Create an empty project. The project will be created in the default folder
//It will be named MyProject1, MyProject2, or similar...
var project = Project.CreateAsync().Result;
// Use project
ArcGIS Pro version: 3.6 or higher.
