ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / ValidateNetworkTopology Method / ValidateNetworkTopology(IEnumerable<Selection>,ServiceSynchronizationType) Method
The set of features/objects to validate. This must be GlobalID-based.
Specifies which implementation of the service endpoint to call. This parameter is ignored for non-services based utility networks.
    Validates the utility network topology within the provided extent according to the provided validation type and selection set. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    selections
    serviceSynchronizationType
    Return Value
    A ValidationResult that describes the result of the operation.
    Exceptions
    ExceptionDescription
    serviceSynchronizationType is invalid.
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when an edit operation is in progress.
    Each ArcGIS.Core.Data.Selection in selections must be GlobalID-based.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.6 or higher.
