ArcGIS.Core.CIM Namespace / CIMMarkerPlacementOnLine Class
Properties Methods Events
    CIMMarkerPlacementOnLine Class Members
    The following tables list the members exposed by CIMMarkerPlacementOnLine.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to angle the marker to the line. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets a value indicating whether to keep the marker upright. This is only considered if AngleToLine is true. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the offset. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the location on a line where a marker will be placed. The direction of the line is determined by the direction in which the line was digitized.
    Public Property Gets or sets the distances from a specified location on a line that a marker will be placed.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMarkerPlacementOnLine.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMarkerPlacementOnLine with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMarkerPlacementOnLine and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
