ArcGIS.Core.CIM Namespace / CIMFormInfo Class
Properties Methods Events
    CIMFormInfo Class Members
    The following tables list the members exposed by CIMFormInfo.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a string that appears in the body of the form as a description.
    Public Property Gets or sets the list of Arcade expressions used in the form.
    Public Property Gets or sets an array of formElement objects that represent an ordered list of form elements.
    Public Property Gets or sets a value indicating whether a previously visible 'formFieldElement' value is retained or cleared when a 'visibilityExpression' applied on the 'formFieldElement' or its parent 'formGroupElement' evaluates to 'false'. Default is 'false'.
    Public Property Gets or sets a string that appears at the top of the form as a title.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFormInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFormInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFormInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
