ArcGIS.Core.CIM Namespace / CIMFormTimestampOffsetPickerInput Class
Properties Methods Events
    CIMFormTimestampOffsetPickerInput Class Members
    The following tables list the members exposed by CIMFormTimestampOffsetPickerInput.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the timestampoffset picker should provide an option to select the timeoffset. If not provided, the default value is 'true'.
    Public Property Gets or sets the maximum timestampoffset to allow.
    Public Property Gets or sets the minimum timestampoffset to allow.
    Public Property Gets or sets the resolution identifier. The default value is Minutes.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFormTimestampOffsetPickerInput.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFormTimestampOffsetPickerInput with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFormTimestampOffsetPickerInput and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
