ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / CircuitTracer Class / Trace Method / Trace(TraceArgument,ServiceSynchronizationType) Method
The input arguments to the trace.
Specifies which implementation of the service endpoint to call. This parameter is ignored for non-services based utility networks.
    Executes a circuit trace.
    Syntax
    Parameters
    traceArgument
    serviceSynchronizationType
    Return Value
    A IReadOnlyList of concrete Result whose type corresponds to ResultType set in TraceArgument.ResultTypes.
    Exceptions
    ExceptionDescription
    traceArgument is null.
    traceArgument is constructed using TraceArgument.TraceArgument Constructor(Subnetwork).
    This operation is not supported in client-server mode.
    -or-
    traceArgument contains unsupported result types.
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
