ArcGIS.Desktop.Editing Namespace / EditOperation Class / Clip Method / Clip(Layer,IEnumerable<Int64>,Geometry,ClipMode,Boolean) Method
The layer of the features to be clipped.
The set of oids of the features to be clipped.
The clipping geometry to clip the features.
Determines the clipping behavior.
Determines when features that are coincident with the clipGeometry boundary, should be retained or removed in certain circumstances.
    Clip a set of features with a geometry.
    Syntax
    Parameters
    layer
    oids
    clippingGeometry
    clipMode
    keepCoincident
    Remarks
    Clip intersects a set of features with a geometry. The resulting geometry is determined by the clipFeatureOptions.
    For ClipMode DiscardArea only, when the clippingGeometry is a polygon, and keepCoincident is true, clipping retains point or line features that are coincident with the polygon clip boundary.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
