ArcGIS.Core.Data Namespace / CoreDataExtensions Class / ReconcileInEditOperation Method / ReconcileInEditOperation(Version,ReconcileOptions,PartialPostOptions) Method
The Version instance to validate.
If ReconcileOptions.TargetVersion is not specified in reconcileOptions, then the target version is the Default version.
Describes the set of features to post.
    Reconciles and partial posts this version against a target version specified in reconcileOptions and partialPostOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function ReconcileInEditOperation( _
       ByVal version As Version, _
       ByVal reconcileOptions As ReconcileOptions, _
       ByVal partialPostOptions As PartialPostOptions _
    ) As ReconcileResult
    Parameters
    version
    reconcileOptions
    partialPostOptions
    Return Value
    An instance of ReconcileResult indicating the results of the operation.
    Exceptions
    ExceptionDescription
    reconcileOptions and/or partialPostOptions is null.
    This operation is not supported in client-server mode because the data store supports multi-branch versioning.
    -or-
    Multi-branch versioning does not support a ConflictResolutionType that favors the target version.
    A Selection object specified in PartialPostOptions.Selections is not from a feature service feature class.
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
