ArcGIS.Desktop.Mapping Namespace / GridOptions Class / SetGridSpacingInMeters Method
Example
    Sets the grid spacing in meters.
    Syntax
    Public Sub SetGridSpacingInMeters( _
       ByVal spacingInMeters As Double _
    public void SetGridSpacingInMeters(
       double spacingInMeters
    Parameters
    spacingInMeters
    Remarks
    This does not change the GridSpacingUnits. They remain unchanged. Use SetGridSpacing to change the spacing units.
    Example
    Set Various Grid Option parameters for GridOptions for a Map
        var center_pt = MapView.Active.Extent.Center;
        var width = MapView.Active.Extent.Width;
        var height = MapView.Active.Extent.Height;
        var qtr_width = width * 0.25;
        var qtr_ht = height * 0.25;
        QueuedTask.Run(() =>
            //use defaults
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
            //customize the options as needed
            gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
            gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
            var gs_rotation = gridOptions.GetGridRotation();
            gridOptions.SetGridRotation(gs_rotation * 1.5);
            var gs_meters = gridOptions.GetGridSpacingMeters();
            var gs_in_spacing_units = gridOptions.GetGridSpacing();
            var gs_units = gridOptions.GridSpacingUnits;
            //meters assumed
            gridOptions.SetGridSpacingInMeters(gs_meters + 10);
            //specify units explicitly
            gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
            gridOptions.IsGridLines = true;//use lines (default)
            var grid_interval = gridOptions.GridMajorInterval;
            gridOptions.SnapToGridEnabled = true;
            var x1 = center_pt.X - qtr_width;
            var y1 = center_pt.Y + qtr_ht;
            gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
            //To apply changes, the gridoptions must be set back on the map
            GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
