ArcGIS.Desktop.Mapping Namespace / GridOptions Class / GridSpacingUnits Property
Example
    Gets and sets the units for the grid spacing
    Syntax
    Public Property GridSpacingUnits As LinearUnit
    public LinearUnit GridSpacingUnits {get; set;}
    Exceptions
    ExceptionDescription
    units cannot be null
    Remarks
    Internally the spacing is always stored in meters. Setting the spacing units affects the returned spacing value only. See GetGridSpacing
    Example
    Set Various Grid Option parameters for GridOptions for a Map
        var center_pt = MapView.Active.Extent.Center;
        var width = MapView.Active.Extent.Width;
        var height = MapView.Active.Extent.Height;
        var qtr_width = width * 0.25;
        var qtr_ht = height * 0.25;
        QueuedTask.Run(() =>
            //use defaults
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
            //customize the options as needed
            gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
            gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
            var gs_rotation = gridOptions.GetGridRotation();
            gridOptions.SetGridRotation(gs_rotation * 1.5);
            var gs_meters = gridOptions.GetGridSpacingMeters();
            var gs_in_spacing_units = gridOptions.GetGridSpacing();
            var gs_units = gridOptions.GridSpacingUnits;
            //meters assumed
            gridOptions.SetGridSpacingInMeters(gs_meters + 10);
            //specify units explicitly
            gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
            gridOptions.IsGridLines = true;//use lines (default)
            var grid_interval = gridOptions.GridMajorInterval;
            gridOptions.SnapToGridEnabled = true;
            var x1 = center_pt.X - qtr_width;
            var y1 = center_pt.Y + qtr_ht;
            gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
            //To apply changes, the gridoptions must be set back on the map
            GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
