| Name | Description | |
![]() | CIMBACalculatedVariableDocument Constructor |
The following tables list the members exposed by CIMBACalculatedVariableDocument.
![]() | Alias | Gets or sets the alias of the variable. |
![]() | AverageBase | Gets or sets the average base of the variable. |
![]() | Build | Gets or sets the build an item was created with. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion) |
![]() | CardViewMode | Gets or sets a value indicating whether to use the Card View mode. |
![]() | Category | Gets or sets the category of the variable. |
![]() | DataSource | Gets or sets the data source used in calculation of distances. Structure of the value is TYPE;COUNTRY_INFO;LOCAL_DATA_INFO where TYPE can be ONLINE, LOCAL, or CUSTOM. COUNTRY_INFO is country_id{|hierarchy}. For example, US|census or US. LOCAL_DATA_INFO is ID of local dataset. For example, USA_ESRI_2019. For example, for local US 2019 dataset it will be: "LOCAL;;USA_ESRI_2019". If online US data source is used, it may be "ONLINE;US|census;". Can act as the value of the baDataSource GP environment variable. https://pro.arcgis.com/en/pro-app/tool-reference/environment-settings/ba-data-source.htm. |
![]() | FieldFormat | Gets or sets how to display the values of the custom variable in reports. |
![]() | HasIndexBase | Gets or sets a value indicating whether the variable has an index base. |
![]() | IndexBase | Gets or sets the index base of the variable. |
![]() | Length | Gets or sets the length of the variable. |
![]() | Name | Gets or sets the name of the variable. |
![]() | OutputType | Gets or sets the output type of the variable. |
![]() | PercentBase | Gets or sets the percent base of the variable. |
![]() | Precision | Gets or sets the precision of the variable. |
![]() | Script | Gets or sets the Python script (expression) which should be calculated. |
![]() | SummaryType | Gets or sets the summary type of the variable. |
![]() | UsedVariables | Gets or sets the variables used in the script expression. For example, if Script is "!RENTER_CY! / !TOTPOP_CY!", UsedVariables contains "RENTER_CY" and "TOTPOP_CY". |
![]() | VariableDefinition | Gets or sets the definition of the variable. |
![]() | Version | Gets or sets document version. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion) |
![]() | Clone | Creates a deep copy of CIMBACalculatedVariableDocument. |
![]() ![]() | FromJson | Reconstructs the CIMBACalculatedVariableDocument with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMBACalculatedVariableDocument and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
