ArcGIS.Core.CIM Namespace / CIMNetCDFRasterDataConnection Class
Properties Methods Events
    CIMNetCDFRasterDataConnection Class Members
    The following tables list the members exposed by CIMNetCDFRasterDataConnection.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the band dimension.
    Public Property Gets or sets the classID of the custom workspace factory.
    Public Property Gets or sets the dataset name.
    Public Property Gets or sets the dataset type.
    Public Property Gets or sets the extent.
    Public Property Gets or sets a value indicating whether or not to invert rows.
    Public Property Gets or sets the selected dimension indexes.
    Public Property Gets or sets the selected dimensions.
    Public Property Gets or sets the selected dimension values.
    Public Property Gets or sets the variable.
    Public Property Gets or sets the vertical dimension.
    Public Property Gets or sets the vertical dimension unit.
    Public Property Gets or sets the workspace connection string.
    Public Property Gets or sets the workspace factory.
    Public Property Gets or sets the X dimension.
    Public Property Gets or sets the Y dimension.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMNetCDFRasterDataConnection.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMNetCDFRasterDataConnection with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMNetCDFRasterDataConnection and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
