ArcGIS.Core.CIM Namespace / CIMPopupInfo Class
Properties Methods Events
    CIMPopupInfo Class Members
    The following tables list the members exposed by CIMPopupInfo.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets Arcade expressions that are referenced as fields in one or more elements in MediaInfos.
    Public Property Gets or sets the pop-up field descriptions.
    Public Property Gets or sets the grid layout for the media infos.
    Public Property Gets or sets the media infos.
    Public Property Gets or sets the field name and the sort order by which the related records will be ordered. The items are defined by the related field name (Format: RelationshipName\\FieldName) as the Keys and the sort order (Enum: Asc, Desc) as the Values.
    Public Property Gets or sets the title.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMPopupInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMPopupInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMPopupInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
