ArcGIS.Core.CIM Namespace / CIMAutoCamera Class
    CIMAutoCamera Class Properties
    For a list of all members of this type, see CIMAutoCamera members.
    Public Properties
     NameDescription
    Public Property Gets or sets the camera type.
    Public Property Gets or sets the camera associated with the map frame.
    Public Property Gets or sets the extent for a map frame when using the fixed constraint.
    Public Property Gets or sets the layer being used to set the camera when using the map frame link constraint.
    Public Property Gets or sets the map frame name being used to set the camera when using the map frame link constraint.
    Public Property Gets or sets the margin value for a map frame with a map frame link constraint.
    Public Property Gets or sets the margin type for a map frame with a map frame link constraint.
    Public Property Gets or sets the margin units for a map frame with a map frame link constraint.
    Public Property Gets or sets the extent constraint associated with the map frame.
    Public Property Gets or sets a value indicating whether the map frame should rotate when using a map frame link constraint.
    Top
