ArcGIS.Core.CIM Namespace / CIMRelateInfoBase Class
Properties Methods Events
    CIMRelateInfoBase Class Members
    The following tables list the members exposed by CIMRelateInfoBase.
    Public Properties
     NameDescription
    Public Property Gets or sets the relate cardinality.
    Public Property Gets or sets the relate data connection.
    Public Property Gets or sets the foreign key.
    Public Property Gets or sets the name.
    Public Property Gets or sets the primary key.
    Public PropertyGets or sets the related layer/table URI. This value is used to disambiguate cases where the same data connection is used by multiple layers or tables in a map.
    Public Property Gets or sets a integer indicating the relate ID when published in a map service.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
