ArcGIS.Core.CIM Namespace / CIMSnappingProperties Class
Properties Methods Events
    CIMSnappingProperties Class Members
    The following tables list the members exposed by CIMSnappingProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets geometric feedback color.
    Public Property Gets or sets a value indicating whether Z snapping is enabled.
    Public Property Gets or sets the snap request type.
    Public Property Gets or sets a value indicating whether the snap tip is fully or partially visible.
    Public Property Gets or sets a value indicating whether snapping to the sketch is enabled.
    Public Property Gets or sets the visual feedback color.
    Public Property Gets or sets the XY tolerance.
    Public Property Gets or sets the XY tolerance unit.
    Public Property Gets or sets the Z tolerance.
    Public Property Gets or sets a value indicating whether Z tolerance is enabled.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSnappingProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSnappingProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSnappingProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
