ArcGIS.Core.CIM Namespace / CIMSpotColor Class
Properties Methods Events
    CIMSpotColor Class Members
    The following tables list the members exposed by CIMSpotColor.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets and sets alpha. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Property Gets or sets the color space of the color. This color space is defined by an ICC color profile (except for spot colors which use a dedicated color space definition). (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Property Gets or sets the spot color name.
    Public Property Gets and sets tint.
    Public Property Gets or sets the values for the color and alpha channels as defined by the color model. Alpha is the last value in the array for all colors. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSpotColor.
    Public MethodOverloaded.  (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSpotColor with a specified state from a JSON encoding.
    Public Method Gets the alpha value of the color. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Method Gets the color component at the specified index. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Method Gets a hash code for the current object. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Sets the alpha value on the color. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public Method Sets the color component at the specified index. (Inherited from ArcGIS.Core.CIM.CIMColor)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSpotColor and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected MethodOverridden.  Returns the index of the alpha color in the color array.
    Protected MethodOverridden.  Creates a Spot color with default values.
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
