ArcGIS.Core.CIM Namespace / CIMSpotColorSpace Class
Properties Methods Events
    CIMSpotColorSpace Class Members
    The following tables list the members exposed by CIMSpotColorSpace.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the standard (non-spot) color that is used to display the color on-screen.
    Public Property Gets or sets the if present, the color used during output.
    Public Property Gets or sets the ID of the book the color name belongs to.
    Public Property Gets or sets a description of the ink. This can provide more information than the name.
    Public Property Gets or sets a value indicating whether or not the color is a referenced color. When this property is true, the alternative color will be looked up from the color book based on the BookID and Name.
    Public Property Gets or sets the defined ink name for the spot color. Usually this is a well-known color standard name.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSpotColorSpace.
    Public MethodOverloaded.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSpotColorSpace with a specified state from a JSON encoding.
    Public Method Gets a hash code for the current object.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSpotColorSpace and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Public Operators
    Returns true if sp1 and sp2 are equal.
    Returns true if sp1 and sp2 are not equal.
    Top
