ArcGIS.Core.CIM Namespace / CIMSymbolReference Class
Properties Methods Events
    CIMSymbolReference Class Members
    The following tables list the members exposed by CIMSymbolReference.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the maximum distance at which symbols are visible. Objects beyond this point don't get rendered.
    Public Property Gets or sets the maximum scale range the symbol reference should be displayed at.
    Public Property Gets or sets the minimum distance at which symbols are visible. Objects closer than this don't get rendered.
    Public Property Gets or sets the minimum scale range the symbol reference should be displayed at.
    Public Property Gets or sets the primitive overrides. Typically set by renderers at draw time.
    Public Property Gets or sets an array of scale dependent sizes.
    Public Property Gets or sets the style path. Reserved for future use.
    Public Property Gets or sets the symbol.
    Public Property Gets or sets the symbol name.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSymbolReference.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSymbolReference with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Methodstatic (Shared in Visual Basic) Returns a symbol from an XML encoding of a CIMSymbol.
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Methodstatic (Shared in Visual Basic) Sets a symbol on a symbol reference from an XML encoding of the symbol.
    Public MethodOverridden.  Creates a JSON encoding of the CIMSymbolReference and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
