ArcGIS.Core.CIM Namespace / LasFilter Class
Properties Methods Events
    LasFilter Class Members
    The following tables list the members exposed by LasFilter.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets and sets the area of interest.
    Public Property Gets and sets the flag enabling the Z-Range filter.
    Public Property Gets and sets the class codes.
    Public Property Gets and sets the class flags.
    Public Property Gets and sets the returns.
    Public Property Gets and sets the surface constraints.
    Public Property Gets and sets the Z maximum filter in meters.
    Public Property Gets and sets the Z minimum filter in meters.
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Reconstructs the LasFilter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Gets the Min and Max Z Range filter values, in meters.
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Sets the Min and Max Z Range filter values, in meters.
    Public MethodOverridden.  Creates a JSON encoding of the LasFilter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
