ArcGIS.Core.Data Namespace / CodedValueDomain Class
    CodedValueDomain Class Methods
    For a list of all members of this type, see CodedValueDomain members.
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the coded value that matches the given name. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a SortedList of the coded values (value and name) maintained by this CodedValueDomain. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the number of codes maintained by this CodedValueDomain. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the description of the domain. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Domain)
    Public MethodGets the FieldType of the domain. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Domain)
    Public MethodOverloaded.
    Top
