ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / ExportRasterTileCache Method
The map whose raster service content will be exported
The parameters to use for the export
Example
    Export raster tile caches from the map using the specified ExportTileCacheParams. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void ExportRasterTileCache(
       Map map,
       ExportTileCacheParams cacheParams
    Public Sub ExportRasterTileCache( _
       ByVal map As Map, _
       ByVal cacheParams As ExportTileCacheParams _
    Parameters
    map
    cacheParams
    Exceptions
    ExceptionDescription
    Map cannot be null
    Extent cannot be null or empty
    Map and extent spatial references must be equal
    No raster tile cache content to export
    Remarks
    Exported tile caches are copied to the specified ExportTileCacheParams.DestinationFolder. Use GetCanExportRasterTileCache to determine if a map has raster service content that can be exported. Raster tile caches can be exported from tiled map services and image services.
    If a map has no raster service content that can be exported a System.InvalidOperationException is thrown. At the conclusion of the export, a layer is created for each exported tile cache.
    Example
    Export Map Raster Tile Cache Content
      //Does the map have any exportable raster content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportRasterTileCache(map);
      var rasterTileExtent = MapView.Active.Extent;
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportRasterTileCacheScales(map, rasterTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = rasterTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale
          //DestinationFolder = .... (optional)
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportRasterTileCache(map, export_params);
    Requirements
