ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / ExportVectorTileCache Method
The map whose vector tile service content will be exported
The parameters to use for the export
Example
    Export vector tile caches from the map using the specified ExportTileCacheParams. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void ExportVectorTileCache(
       Map map,
       ExportTileCacheParams cacheParams
    Public Sub ExportVectorTileCache( _
       ByVal map As Map, _
       ByVal cacheParams As ExportTileCacheParams _
    Parameters
    map
    cacheParams
    Exceptions
    ExceptionDescription
    Map cannot be null
    Extent cannot be null or empty
    Map and extent spatial references must be equal
    No vector tile cache content to export
    Remarks
    Exported vector tile caches are copied to the specified ExportTileCacheParams.DestinationFolder. Use GetCanExportVectorTileCache to determine if a map has vector tile service content that can be exported.
    If a map has no vector tile service content that can be exported a System.InvalidOperationException is thrown. At the conclusion of the export, a layer is created for each exported vector tile cache.
    Example
    Export Map Vector Tile Cache Content
      var mapVectorTileExtent = MapView.Active.Extent;
      //Does the map have any exportable vector tile content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale,
          DestinationFolder = @"C:\Data\Offline"
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
    Requirements
