ArcGIS.Desktop.Editing Namespace / EditOperation Class / Planarize Method / Planarize(Layer,Int64,Double,LinearUnit) Method
The layer of the features to planarize.
The oid of the feature to planarize.
The cluster tolerance used while planarizing features(> xyTolerance of data).
The linear unit of the cluster tolerance.
Example
    Planarize features.
    Syntax
    Public Overloads Sub Planarize( _
       ByVal layer As Layer, _
       ByVal oid As Long, _
       ByVal clusterTolerance As Double, _
       ByVal clusterToleranceUnit As LinearUnit _
    Parameters
    layer
    oid
    clusterTolerance
    Exceptions
    ExceptionDescription
    Layer cannot be null.
    clusterToleranceUnit cannot be null.
    Insufficient license. This method requires a standard license.
    Example
    Edit Operation Planarize Features
    // Planarizes the specified feature in the given feature layer.
    await QueuedTask.Run(() =>
        // note - EditOperation.Planarize requires a standard license.
        //  An exception will be thrown if Pro is running under a basic license.
        var planarizeFeatures = new EditOperation() { Name = "Planarize Features" };
        // Planarize one or more features
        planarizeFeatures.Planarize(featureLayer, [objectId]);
        // Execute to execute the operation
        // Must be called within QueuedTask.Run
        if (!planarizeFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = planarizeFeatures.Execute();
          //or use async flavor
          //await planarizeFeatures.ExecuteAsync();
    Edit Operation Perform a Clip, Cut, and Planarize
    // Performs a sequence of editing operations on a feature, including clipping, cutting, and planarizing.
        //Multiple operations can be performed by a single
        //edit operation.
        var clipCutPlanarizeFeatures = new EditOperation() { Name = "Clip, Cut, and Planarize Features" };
        clipCutPlanarizeFeatures.Clip(featureLayer, objectId, clipPolygon);
        clipCutPlanarizeFeatures.Split(featureLayer, objectId, cutLine);
        clipCutPlanarizeFeatures.Planarize(featureLayer, objectId);
        if (!clipCutPlanarizeFeatures.IsEmpty)
          //Note: An edit operation is a single transaction.
          //Execute the operations (in the order they were declared)
          clipCutPlanarizeFeatures.Execute();
          //await clipCutPlanarizeFeatures.ExecuteAsync();
    Requirements
