ArcGIS.Core.Geometry Namespace / PolygonBuilderEx Class / CreatePolygon Method / CreatePolygon(IEnumerable<Coordinate3D>,SpatialReference) Method
Coordinates to create the polygon. Line segments are created from the coordinates.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a new instance of the Polygon class.
    Syntax
    Public Overloads Shared Function CreatePolygon( _
       ByVal coordinate3Ds As IEnumerable(Of Coordinate3D), _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polygon
    Parameters
    coordinate3Ds
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    coordinate3Ds is null.
    Remarks
    The HasZ property is set to true.
    Example
    Get the individual parts of a multipart feature
    IEnumerable<Geometry> MultipartToSinglePart(Geometry inputGeometry)
      // list holding the part(s) of the input geometry
      List<Geometry> singleParts = new List<Geometry>();
      // check if the input is a null pointer or if the geometry is empty
      if (inputGeometry == null || inputGeometry.IsEmpty)
        return singleParts;
      // based on the type of geometry, take the parts/points and add them individually into a list
      switch (inputGeometry.GeometryType)
        case GeometryType.Envelope:
          singleParts.Add(inputGeometry.Clone() as Envelope);
          break;
        case GeometryType.Multipatch:
          singleParts.Add(inputGeometry.Clone() as Multipatch);
          break;
        case GeometryType.Multipoint:
          var multiPoint = inputGeometry as Multipoint;
          foreach (var point in multiPoint.Points)
            // add each point of collection as a standalone point into the list
            singleParts.Add(point);
          break;
        case GeometryType.Point:
          singleParts.Add(inputGeometry.Clone() as MapPoint);
          break;
        case GeometryType.Polygon:
          var polygonNew = inputGeometry as Polygon;
          foreach (var polygonPart in polygonNew.Parts)
            // use the PolygonBuilderEx turning the segments into a standalone
            // polygon instance
            singleParts.Add(PolygonBuilderEx.CreatePolygon(polygonPart));
          break;
        case GeometryType.Polyline:
          var polylineNew = inputGeometry as Polyline;
          foreach (var polylinePart in polyline.Parts)
            // use the PolylineBuilderEx turning the segments into a standalone
            // polyline instance
            singleParts.Add(PolylineBuilderEx.CreatePolyline(polylinePart));
          break;
        case GeometryType.Unknown:
          break;
        default:
          break;
      return singleParts;
    Get Sub-curve of a polyline or polygon
      SpatialReference sr = SpatialReferences.WGS84;
      List<Coordinate2D> coords =
        new Coordinate2D(-111, 72),
      new Coordinate2D(-108, 68),
      new Coordinate2D(-114, 68)
      polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
      Polyline subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 5, AsRatioOrLength.AsLength);
      // subCurve.PartCount = 1
      // subCurve.PointCount = 2
      ReadOnlyPointCollection points = subCurve.Points;
      // points[0] = -111, 72
      // points[1] = -108, 68
      subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 0.5, AsRatioOrLength.AsRatio);
      // subCurve.PointCount = 3
      // points[2] = -108.5, 68
      List<Coordinate3D> coords3D =
        new Coordinate3D(0, 0, 0),
      new Coordinate3D(0, 1, 1),
      new Coordinate3D(1, 1, 2),
      new Coordinate3D(1, 0, 3)
      polygon = PolygonBuilderEx.CreatePolygon(coords3D, sr);
      subCurve = GeometryEngine.Instance.GetSubCurve3D(polygon, 0, 1, AsRatioOrLength.AsLength);
      // subCurve.HasZ = true
      // points.Count = 2
      // points[0] = 0, 0, 0
      // points[1] = 0, 0.70710678118654746, 0.70710678118654746
    Replace NaN Zs in a polygon
      List<Coordinate3D> coordsZ =
        new Coordinate3D(1, 2, double.NaN),
      new Coordinate3D(4, 5, 3),
      new Coordinate3D(7, 8, double.NaN)
      polygon = PolygonBuilderEx.CreatePolygon(coordsZ);
      // polygon.HasZ = true
      Polygon polygonZReplaced = GeometryEngine.Instance.ReplaceNaNZs(polygon, -1) as Polygon;
      // polygonZReplaced.Points[0].Z = -1
      // polygonZReplaced.Points[1].Z = 3
      // polygonZReplaced.Points[2].Z = -1
    Union many Polygons
      // union many polygons
        new Coordinate3D(1, 2, 0), new Coordinate3D(3, 4, 1), new Coordinate3D(4, 2, 2),
      new Coordinate3D(5, 6, 3), new Coordinate3D(7, 8, 4), new Coordinate3D(8, 4, 5),
      new Coordinate3D(9, 10, 6), new Coordinate3D(11, 12, 7), new Coordinate3D(12, 8, 8),
      new Coordinate3D(10, 8, 9), new Coordinate3D(12, 12, 10), new Coordinate3D(14, 10, 11)
      // create polygons
      List<Polygon> manyPolygonsZ =
        PolygonBuilderEx.CreatePolygon([coordsZ[0], coordsZ[1], coordsZ[2]], SpatialReferences.WGS84),
        PolygonBuilderEx.CreatePolygon([coordsZ[3], coordsZ[4], coordsZ[5]]),
        PolygonBuilderEx.CreatePolygon([coordsZ[6], coordsZ[7], coordsZ[8]])
      polygon = GeometryEngine.Instance.Union(manyPolygonsZ) as Polygon;
    Requirements
