ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(Multipoint,SpatialReference) Method
The multipoint to create the polyline. Line segments are created from the points in the multipoint.
(Optional) The SpatialReference. The default value is null. If spatialReference is null, then the spatial reference will be inherited from multipoint.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    Public Overloads Shared Function CreatePolyline( _
       ByVal multipoint As Multipoint, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polyline
    Parameters
    multipoint
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    multipoint is null.
    Remarks
    HasZ, HasM and HasID attributes are inherited from the input multipoint.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Requirements
