ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(IEnumerable<Coordinate3D>,SpatialReference) Method
Coordinates to create the polyline. Line segments are created from the coordinates.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    Public Overloads Shared Function CreatePolyline( _
       ByVal coordinates As IEnumerable(Of Coordinate3D), _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polyline
    Parameters
    coordinates
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    coordinates is null.
    Remarks
    The HasZ property is set to true.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Interpolate Z values on a polyline
      List<Coordinate3D> coords2 =
      new Coordinate3D(0, 0, 0),
      new Coordinate3D(0, 1000, double.NaN),
      new Coordinate3D(1000, 1000, 50),
      new Coordinate3D(1000, 1000, 76),
      SpatialReference sr = SpatialReferences.WebMercator;
      polyline = PolylineBuilderEx.CreatePolyline(coords2, sr);
      // polyline.HasZ = true
      // polyline.Points[1].HasZ = true
      // polyline.Points[1].Z  = NaN
      // polyline.Points[4].HasZ = true
      // polyline.Points[4].Z  = NaN
      Polyline polylineNoNaNZs = GeometryEngine.Instance.CalculateNonSimpleZs(polyline, 0) as Polyline;
      // polylineNoNaNZs.Points[1].HasZ = true
      // polylineNoNaNZs.Points[1].Z = 25  (halfway between 0 and 50)
      // polylineNoNaNZs.Points[4].HasZ = true
      // polylineNoNaNZs.Points[4].Z = 38  (halfway between 76 and 0)
    MovePointAlongLine
      LineSegment line = LineBuilderEx.CreateLineSegment(MapPointBuilderEx.CreateMapPoint(0, 3), MapPointBuilderEx.CreateMapPoint(5.0, 3.0));
      polyline = PolylineBuilderEx.CreatePolyline(line);
      bool simple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
      // ratio = false
      MapPoint pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 0.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 3.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, -1.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 4.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 2.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 1.0
      // ratio = true
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt = 2.5, 3.0
      // move past the line
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.NoExtension);
      // pt = 5.0, 3.0
      // move past the line with extension at "to" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt = 7.0, 3.0
      // negative distance with extension at "from" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, -2, false, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // pt = -2.0, 3.0
      // ratio = true
      // pt = 2.5, 3.0
      // line with Z
      List<Coordinate3D> coords3D = [new Coordinate3D(0, 0, 0), new Coordinate3D(1113195, 1118890, 5000)];
      Polyline polylineZ = PolylineBuilderEx.CreatePolyline(coords3D, SpatialReferences.WebMercator);
      // polylineZ.HasZ = true
      // ratio = true, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 556597.5
      // pt.Y = 559445
      // pt.Z = 2500
      // ratio = true, past the line with "to" extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 1.5, true, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt.X = 1669792.5
      // pt.Y = 1678335
      // pt.Z = 7500
      // ratio = true, negative distance past the line with no extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, -1.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 0
      // pt.Y = 0
      // pt.Z = -7500
      // polyline with Z but 2d distance = 0
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(5, 5, 0);
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      List<MapPoint> pts = [pt3, pt4];
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      // polyline.Length3D = 10
      // polyline.Length = 0
      MapPoint result = GeometryEngine.Instance.MovePointAlongLine(polyline, 2, false, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 2
      // polyline with length2d = 0 and length3d = 0
      MapPoint pt5 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      MapPoint pt6 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      pts.Clear();
      pts.Add(pt5);
      pts.Add(pt6);
      // polyline.Length3D = 0
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 10
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // polyline with Z and M
      List<MapPoint> inputPoints =
          MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4),
        MapPointBuilderEx.CreateMapPoint(1, 2, 33, 44),
      Polyline polylineZM = PolylineBuilderEx.CreatePolyline(inputPoints, SpatialReferences.WGS84);
      // polylineZM.HasZ = true
      // polylineZM.HasM = true
      MapPoint pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 18, 24
      // ratio = true with offset
      pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.2, true, 2.23606797749979, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 9, 12
    Set all Zs in a polyline
      List<Coordinate3D> coordsZ =
        new Coordinate3D(1, 2, 3),
      new Coordinate3D(4, 5, 6),
      new Coordinate3D(7, 8, double.NaN)
      polyline = PolylineBuilderEx.CreatePolyline(coordsZ);
      Polyline polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, -1) as Polyline;
      // polylineSetZ.Points[0].Z = -1
      // polylineSetZ.Points[1].Z = -1
      // polylineSetZ.Points[2].Z = -1
      polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.NaN) as Polyline;
      // polylineSetZ.Points[0].HasZ = true
      // polylineSetZ.Points[0].Z = NaN
      // polylineSetZ.Points[1].HasZ = true
      // polylineSetZ.Points[1].Z = NaN
      // polylineSetZ.Points[2].HasZ = true
      // polylineSetZ.Points[2].Z = NaN
      polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.PositiveInfinity) as Polyline;
      // polylineSetZ.Points[0].Z = double.PositiveInfinity
      // polylineSetZ.Points[1].Z = double.PositiveInfinity
      // polylineSetZ.Points[2].Z = double.PositiveInfinity
    SimplifyOGC
      SpatialReference sr = SpatialReferences.WGS84;
      Coordinate2D[] coords = [new Coordinate2D(5, 10), new Coordinate2D(15, 20), new Coordinate2D(25, 10), new Coordinate2D(5, 20)];
      polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
      // polyline.IsKnownSimpleOgc = false
      // polyline.IsKnownSimple = false
      bool isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out NonSimpleReason nonSimpleReason, true);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.SelfIntersections
      Polyline simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline) as Polyline;
      // simplePolyline.IsKnownSimpleOgc = true
      // simplePolyline.IsKnownSimple = true
      double resolution = sr.XYResolution;
      Coordinate3D[] coords3D = [ new Coordinate3D(0, 0, 0), new Coordinate3D(0, 1.8 * resolution, 0.8 * sr.ZTolerance), new Coordinate3D(10, 10, 1),
    new Coordinate3D(0, 5, 1) ];
      polyline = PolylineBuilderEx.CreatePolyline(coords3D, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out nonSimpleReason);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.ShortSegments
      simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline, true) as Polyline;
      coords = [new Coordinate2D(0, 0), new Coordinate2D(0, 0)];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(coords, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(multipoint, out nonSimpleReason);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.DuplicateVertex
    Requirements
