ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(IEnumerable<IEnumerable<Segment>>,AttributeFlags,SpatialReference) Method
Parts to create the polyline.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null. The spatial reference of each segment is ignored.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    Parameters
    parts
    attributes
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    parts is null.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Requirements
