ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(Segment,AttributeFlags,SpatialReference) Method
A segment to create the polyline.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null. If spatialReference is null, then the spatial reference will be inherited from segment.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    Public Overloads Shared Function CreatePolyline( _
       ByVal segment As Segment, _
       ByVal attributes As AttributeFlags, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polyline
    Parameters
    segment
    attributes
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    segment is null.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Create Bezier Curve Element
      await QueuedTask.Run(() =>
      //Build geometry
      Coordinate2D pt1 = new Coordinate2D(1, 7.5);
      Coordinate2D pt2 = new Coordinate2D(1.66, 8);
      Coordinate2D pt3 = new Coordinate2D(2.33, 7.1);
      Coordinate2D pt4 = new Coordinate2D(3, 7.5);
      var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
      var bezSeg = bez.ToSegment();
      Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
      //Set symbology, create and add element to layout
      CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
        ColorFactory.Instance.RedRGB, 4.0, SimpleLineStyle.DashDot);
      ElementFactory.Instance.CreateGraphicElement(layout, bezPl, lineSym, "New Bezier");
    Requirements
