ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(IEnumerable<Polyline>,AttributeFlags,SpatialReference) Method
Polylines to create the polyline.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null. The spatial reference of each polyline is ignored.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    Public Overloads Shared Function CreatePolyline( _
       ByVal polylines As IEnumerable(Of Polyline), _
       ByVal attributes As AttributeFlags, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polyline
    Parameters
    polylines
    attributes
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    polylines is null.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Requirements
