ArcGIS.Core.CIM Namespace / CIMClusteringFeatureReduction Class
Properties Methods Events
    CIMClusteringFeatureReduction Class Members
    The following tables list the members exposed by CIMClusteringFeatureReduction.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the radius within which points are clustered. Units are points.
    Public Property Gets or sets a value indicating whether feature reduction is enabled in the feature layer. (Inherited from ArcGIS.Core.CIM.CIMFeatureReduction)
    Public Property Gets or sets the fields that should be shown with the aggregated features. (Inherited from ArcGIS.Core.CIM.CIMAggregationFeatureReduction)
    Public Property Gets or sets the maximum scale. Beyond this scale, unclustered points will be shown.
    Public Property Gets or sets the popup info for the aggregated features. (Inherited from ArcGIS.Core.CIM.CIMAggregationFeatureReduction)
    Public Property Gets or sets the visualization used by the clusters.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMClusteringFeatureReduction.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMClusteringFeatureReduction with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMClusteringFeatureReduction and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
