ArcGIS.Core.CIM Namespace / CIMTiltShiftEffect Class
Properties Methods Events
    CIMTiltShiftEffect Class Members
    The following tables list the members exposed by CIMTiltShiftEffect.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the strength (0-1) of the tilt-shift blur.
    Public Property Gets or sets the width of the blurred area starting from the bottom of the screen measured in points.
    Public Property Gets or sets a value indicating whether the effect should be applied to the scene. (Inherited from ArcGIS.Core.CIM.CIMCameraEffect)
    Public Property Gets or sets the width of the blurred area starting from the left of the screen measured in points.
    Public Property Gets or sets the width of the blurred area starting from the right of the screen measured in points.
    Public Property Gets or sets the width of the blurred area starting from the top of the screen measured in points.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTiltShiftEffect.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTiltShiftEffect with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTiltShiftEffect and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
